Kilpsch Synergy Sub12
gr_babu
plz suggestions regarding Kilpsch Synergy Sub12 ,
any other better brand , ur suggestion plzz,
purpose mostly movies and little of music.
i am cosidering wharfedale sw150, polk dsw 500, Kilpsch Synergy Sub12 or sholud i streach my buget to velodyne spl 100r
suggestions plzz
thx
Hi, babu,
Klipsch synergy 12 just looks big. It is not good. If you want klipsch go for reference series
Kilpsch Reference RF-10d 260W which is around 28k or
Kilpsch Reference RPW-10 260W 22k.
Or try Polk audio with remote very good with movies
Polk Audio DSW-PRO500 375W 20k
Polk Audio DSW-PRO600 460W 25k.
Velodyne can't say except that they are really expensive. Not heard them though.
cheers
Next WF 150 is useless. Try 250 38k
thx for the reply
ill go have a look at polk dsw 600
i have not auditoned kilpsch referance series.
where in chennai can i have demo .
thx for reply
Babu,
Do check out the Mordaunt-Short MS309i, Audioengine S8
Audioengine S8, its priced around the same as the other subs you have mentioned do audition it and see if its to your taste.
The mentioned subs are better for movies than for music so if its for movies these should worth the money you spend.
Audio Engine dealer in India is
Bajaao.com
Ashutosh Pandey(Bombay)
Tel: 9322338513
Got the above address from their website you can check with him regarding its availability in chennai.
For Modraunt short there are chennai dealers.
Cressida AV Zone
85/16, East Mada Street
Tiruvanmiyur
Chennai
COntact Person: Mr. R Ravi Kumar :
+91 98409 39774
Home Taalkies
No.50-A / 51-A, J N 100 Feet Road,
Near Laxman Shruthi Musicals,
Chennai, Tamil Nadu
India
600026
M V Baalaji Sundar
Telephone: + 91 - 09941879393
Home Taalkies are the exclusive distributors for Mordaunt-Short for the region of Tamil Nadu
Hope it helps
thx for reply,
ill have a look at Mordaunt-Short MS309i , then let u knoew.
thx
