Klipsch RF82 speakers
Hi anm and iaudio
I am posting the picture of setup for connecting two amps to one set of speakers.
There are two sets of four banana plugs fixed on the wooden piece.
Each set connects to one amp ie the first set to tube amp and second to Onkyo amp. The banana plugs connected to speakers are shifted from one amp to another by just removing them from one set of banana plugs to another.
Anil.
My First DYI Transmission Line Speakers
Photographs of my first Transmission Line speaker system some details below,
Woofer - 6.5" Peerless Kevelar cone for tight bass and smoother mid-range (wide range drivers)
Tweeter - 1" Low Fs Peerless Aluminium Dome for smooth and mellow highs (wide range drivers)
Enclosure Type - Transmission Line with traingular wave guides, Time aligned enclosure (coherent sound stage) and diffraction corrected.
Tuning frequency - 34Hz
Frequency Response (-6dB) - 19Hz to 22KHz
Sensitivity - 91dB/w/m
Cross-over - 1st order zero phase shift Butterworth cross-over network, zobel correction, L-pad, parallel and series notch, contour circuits and Baffel step compensators.
Nominal Power - 150 Watts
Nominal Impedance - 6 ohms
Cross-over frequency - 3000Hz
Features:
- Guided wave Transmission Line enclsoure ensure no boomy bass stimulating atmosphere of live performance and extended dynamics
-Wide range drivers ensure optimum performance in the enitre frequency band-width of the speaker system
-1st order filter, time alignment and diffraction compensation on the baffel ensures Excellent on & off- axis response
-Harmonics balanced to ensure real life performance of music and vocals
-Zero phase-shift 1st order Butterworth filter ensures excellent transient response without ringing/ ripple effect and faster settling times for the filter due to fewer passive components
Features:
Good Show Hari! What was the complete expenditure for the speakers build???
dranil, thanks for sharing. Does anyone else in the family find it easy to use, or rely on you to do the switching?
Hi anm
Good question:)
Anybody can just pullout the banana plug and change it to the other one.
