Klipsch speaker RF - 62
legin
just heard the Klipsch RF - 62
Sound - bass was great ,treble was sweet overall great speaker
cost Rs.65000/-
lookin at them to power with the NAD 355BEE
Pls give me some feed back
Hi legin,
Where did u demo the RF-62's??? They were paired with???
Was Manoj the sales rep?? If you are going to pair them for 2 ch purpose, suggest you take your amp there & pair the 62's to it. Have you already got the NAD or r you thinking about it? Pls do this amp pairing & see if you like the combo.
Hi i have RF-52 for last 1 1/2 year and they sound wonderful to me for music. best part is the speakers being highly sensitive can be paired with a SET amp and really sound great. RF-62 must be definitely better :clapping:
Klipsch has been better with a home theater setup normally. I haven't heard them so no comments. Looks a bit boxy for my taste (but typical Klipsch design)
Have you auditioned other speakers? I'd guess you are a bass person :)
Excellent advice - Klipsch speakers pair very well with low power tube amps.
will do tht with the amp my only worry is as the highs are horn tweeters will there be ear fatigue after listen for a long time also the sensitivity of the speakers is 97 [email protected] +3 or -3db and they sound very close to the monitor BR3 which I have
I heard them for close to 5 hrs non stop & had no ear fatigue. Advice you do the same:D:lol::D
I had RF 62 for almost 2 years. Finally sold them since they were too bright as well as extended listening was not enjoyable. Also the price looks very high. The correct price should be in the range of 45K for new.
I'm having Rf-10 FS and RC-10 Center, for two channel music i use pure direct mode in my yammy amp connected after emotiva XDA-1 through emotiva interconnects, to me they turned to be very musical after i added emotiva in set up, earlier also, initially they sounded little bright but after 100 hrs or so, the brightness was balanced by lot of improvement in mids after break in, now it is most soothing set up for me, i generally listen jagjit,bollywood oldies and new both and off course punjabi-(fan of gurdas mann). as of my personal experience try to audition klipsch after break in period if possible.
regards
sukhjit
Hi, I had purchased Klipsch RF-52 towers with rest of 5.1 HT set along with Marantz SR 5002 AVR. Later on i added Norge Millenium 2000 amp to the set and the highs were bright and ear fatiguing. Then i went for Lyrita SET amp and at present am experiencing excellent music reproduction without any ear fatigue whatsoever on extended sessions. Klipsch are bright for highs and a tube amp roles the highs just that much to sound just right. I think with a SS amp and KLipsch you will be disappointed. Thats my experience and two penny advice..
