laptop speakers
I am not sure what your budget is, so I will suggested some basic models under Rs 1k - F&D V620 and F&D V560.
F&D V620
I think F&D V620 has the best sound quality when compared to other models in this price range. The unit produces good amount of bass and decent treble for its size and price. The build quality is good and is slightly heavier than F&D V560.
F&D V560
If you want speakers which are light and easy to carry around then F&D 560 would be a good choice, if you have a laptop with a thin bezel then the speakers can be clipped on to the sides of the laptop's display but it is not possible to clip it on to regular laptops with a thick bezels. The sound quality is almost as good as F&D V620, but the bass reproduction is slightly lower than F&D V620. It also comes with a carrying pouch and is priced below the F&D V620.
There are video reviews of both the speakers on Youtube, so have a look at them and decide.
