lg 42lm6410 vs 42lm6690 help needed
rphall
kolkata
I would like to buy a 3d tv around 65k. SInce lg 3d with the passive technology are the best, I have selected 2 tvs :
lg 42lm6410 : Rs 60k
lg 42lm6690 : Rs 70k
I would like to know if there is much difference between the two in terms of PQ and whether I should buy 42lm6690 for Rs 10k extra.
As par as my idea is concerned lg 42lm6410 is a Last Year Model. Go for 6690 if possible since it has got good review points.
As you know LG is best known for 3D but if you watch mostly 2D stuffs and rarely 3D materials then you may also consider SONY Bravia 42W800.
If you are not opposed to Plasma then you can get bigger screen sizes in the same budget from manufacturers like LG, Samsung or Panasonic with 3D.
Im using Lg42lm6410... and im loving it. Dunno about 2d of other tvs but this is a budget friendly tv with many features. Even though its a 1 year model its the best in this price category
These are 2012 models and the price quoted is not as low as one expect in 2013 when 2013 models are out in the market already. So I would advise you to bargain hard and if u want 2012 model, then go for 6690, peovuded it is not a display piece or else go for 2013 ln series models if u want lg, or Sony w 800 is also a grt passive 3d available.
