Low cost Class D amp kits in India
Most kits might have the same level of ease or difficulty assembling . Typically designs with SMD parts are harder to assemble. But with experience even that isn't so difficult.
So just pick by the specs or functions you want. If you are not experienced in assembling pick one with minimal smd parts. Usually the main chip is an smd device . Like the L20D classD power amp by LJM on eBay.com .
I would stick to units with a protection relay. So if something goes wrong it will not take the speaker with it ! :)
