Lumin + LPS: The most significant improvement to my audio chain
JaideepGiridhar
After having installed an LHY SW-8 switch with LPS and routing the fibre connection into it using two FMCs and SFP units, I swapped my Lumin U2 Mini for a Lumin U1 hooked to a Lumin LPS. The change in SQ has to be heard to be believed. It's of an order that's exponential. The sound stage and transients are breathtaking. Every other aspect of music is elevated to greater heights. The unit itself has reassuring heft - I don't think Lumin builds these out of single aluminium billets any longer. I plan to upgrade the LPS to an X1, which I believe is significantly better.
