S shajijacob New Member Joined Mar 27, 2011 Messages 25 Points 0 Location kerala Feb 26, 2012 #1 can we combine ma gold center with silver bookshelfs for a home theatre set up?
M marsilians Well-Known Member Joined Dec 8, 2008 Messages 2,604 Points 83 Location 117.192.87.109 Feb 26, 2012 #2 shajijacob said: can we combine ma gold center with silver bookshelfs for a home theatre set up? Click to expand... How is your setup going to be - i.e., which speakers will be gold vs. silverline?
N navin advani Well-Known Member Joined May 31, 2010 Messages 668 Points 63 Location Mumbai Feb 26, 2012 #3 Keep front 3 speakers from the same line. So you can have Gold front and center and silver rears.
S shajijacob New Member Joined Mar 27, 2011 Messages 25 Points 0 Location kerala Feb 26, 2012 #4 can we combine gold centre with silver as bookshelfs l/r
A afj Well-Known Member Joined Sep 12, 2008 Messages 2,105 Points 83 Location hyderabad Feb 27, 2012 #5 shajijacob said: can we combine ma gold center with silver bookshelfs for a home theatre set up? Click to expand... it may not be ideal but yes you can. just check the power ratings of the amplifier to make sure they match both speakers
X X man Active Member Joined Nov 6, 2011 Messages 299 Points 28 Location Mumbai Feb 28, 2012 #6 IF you have centre speakers from a different series, it will be very noticeable when sound moves between the three speakers. Suggest keep all fronts same. Rears not so important.
