multiple speakers on a single channel
Jeemon
dubai
hi all , i have a onkyo TX NR 656 AV Receiver and i want to add 2 speakers on each surround channels .i have 6 ohm wharfedale vardus surround speakers and its 6 ohms .my question is if i connect 2 speakers each parallel/series is this going to damage my amp ?
and i want to use 2 each speakers for atmos channel (ceiling )
can some one advice :clapping:
Any reason you want to add 2 speakers per surround channel?
Most of the av receivers are not 3 ohms stable (parrelleing ruled out). At 12 ohm load (series), the output power of receiver will be damn low, end up having lower output than a single 6 ohm speaker as load. Not a great idea at all.
Drive safe,
JVS
Don't even try it, unless you want to see white smoke from your receiver. Please Google for affect on impedance and power requirements when speakers connected and parallel and in series.
Avoid connecting more than a single speaker per channel.
MaSh
Sent from my Redmi Note 3
@Jeemon its bad idea mate, you dont do that. you may try something with delhi made universal amps and speakers, lol . but not with these once.
It will burn, your amp and your as* aswell.
If you want to make another channel of atmos, just get any decent amp, may be a budget amp of 35 to 45 watts, or get 2nd hand from olx, from someone.
Take preout from your atmos channel and give it to external amp. that i think will solve issue of getting duplicate channel. And its safe way. Then you match the volume level of your speakers to that amp, and run your room calibration.
My 2 cents.....
It is not such a doomsday scenario if one connects say 2 speakers in series. I have used 2 stand mounts connected in series for the centre channel to good effect and with no harm to the receiver.
Connecting them in parallel is not a good idea because the amp sees a halved load and may not be able to handle it.
how can i take pre out ? the bluray dosent have 7.1 out .i have connected this via HDMI , any advices ?
how to take the pre out ? it got only HDMI out and no pre outs in the receiver also. i have tx nr 313 and i can use that by splitting the hdmi . but still how the atmos goin to work ?
Hello you cant get it work like that, if you split hdmi, your TX313 will still give out only 5.1.
In your 656, can you assign Zone 2 as new channel? is there option to assign channel? Please go through your manual. I have receiver in which i can assign the Back surround as either zone 2 or as back channel. so check if you have certain possibility. If not then i dont see other options that could work properly.
good luck!
