my new diy stands
good work
:clapping:
your ns-1000 stands are the inspiration for me to build a wooden stands for JBL L96
you are living in his majesty su... qa... bi... sa... city ma...
thanks mate.you liked my yam ns 1000m stands.
this is my project to justice jbls.
the support columns are 3"box column and the plate is 8mm thick.
placed 9.5mm holes on both top and bottom for M10 Spikes.
the welder suggested hot paint,it will give very good finish and long last.
the object heated to particular temp and paint applied by atom spray.will decide once hardware job completes.
not decided yet, but the speakers are very very heavy.may not needed.but will make holes on top for future filling.:)
Nice effort. Why don't you host the pics on a good photo hosting site like photobucket and post pics directly in the thread rather than post the hyperlinks?
Good design, good support, right height well suiting the speakers. Good construction, also the colour. The colour matches the driver cones well. I assume the speaker grills are also black. Would be nice if you can keep these beauties in a dim warm lighted place.;)
Thanks for your supporting words.will keep in main room after painting finishes.:)
