Need a 5.2 channel amplifier
ketansethi1987
Delhi
Hi!
Is there any 5.2 channel amplifier available?
I wan to use satellites of entry level 5.1 channel system that would cost around Rs. 3000/-
Along with the satellites I want to use 2 12 inch woofers
My requirement is an amplifier that can power these small satellites and 2 12 inch woofers
It should be low power satellite but a high power woofer amp.
Gues Ill have to make one on my own.
I already have a 2 channel amp that can power 2 12 inches but I have to switch on 2 different things i.e. the 5.1 and the subs plus I cant use a pen drive in one and listen to music in both at the same time.
For the time being will get a new amp now with audio out.
Is there a 5.1 channel amp that may power a 12 inch along with 5 satellites?
I have seen this but do not think it will be able to drive any 12 inch subwoofer plus this is working at 8 ohms and my woofer would be around 4-6 ohms power is 22 w per chanel should be atleast 100-200 wat for woofers
