Need a perfect receiver to setup my 5.1 Home Theatre
Heart beats
Kottayam,Kerala
Hai guys.. you guys helped me to setup my tv & HT system.. :clapping: :clapping:
Now i want a perfect A/V receiver for following setup >
46HX850 Sony 3d Tv
Polk Audio Monitor60 Series II (Front)
Polk Audio Monitor 40 (Rear)
Polk Audio CS2 Series II Center Channel Speaker
Polk Audio PSW505
Or
Bic f12
Need a matching Receiver to complete my setup
Any other home theatre suggestions are also welcome.. :)
Polk has no issues with Onkyo, Denon & Yamaha.Pioneer can be a bit bright,but need to check.
ok if demo is not possible...try demoing your models if they are avilable in shop with different avr.......it will help you to decide...
but can take denon at a shot...
Look for Onkyo receiver. They will go really well with polks. I'd start with NR616 if you have budget 818.
Yes you can bi-amp the surround back/high and I noticed most of the 5.1 receivers come with minimal power. So better go with a 7.2.
Straight choice between these receivers... please help me choose 1...
ONKYO TX-NR515 7.2-Channel Network A/V Receiver
Onkyo TX-NR717 7.2-Channel Home Theater A/V Receiver
Pioneer VSX-1122-K 7.2-Channel Network Ready A/V Receiver
Pioneer SC-1222-K 7.2-Channel Network Ready AV Receiver
Yamaha RX-V673 7.2-Channel Network AV Receiver
What's a class D receiver ??
Class D3 Amplification
The SC-1222s Class D3 7-channel amplifier is one of the most powerful amplifiers of any multi-channel A/V receiver Pioneer has ever produced. Designed for audiophiles, Class D3 amplification features a direct signal path, with no EMI filters, feedback loops, or current limiters. Unlike regular amps, Class D3 amplifiers are 4-OHM certified so they safely power those low-impedance speakers that other receivers just cant handle. These amplifiers run cool, using just a fraction of the energy of less efficient designs. Class A/B amplifiers simply cannot match the efficiency of Class D3 as their power output per channel diminishes rapidly when more channels are added to the work-load. This kind of unprecedented power capability allows you to appreciate the full dynamics from any media source in a way never before possible.
Source : Pioneer USA, Car Stereo, Speakers, Home Theater, Navigation, DJ | Pioneer Electronics USA
