Need advice on Lloyd tv
sadiquetajbhai
ankleshwer
Guys i am thinking to buy Lloyd 40inch tv. Price 27000 with 3 years warrenty. Need your advice on its panel and overall performance. Is it worth to buy?
As long as you are sure that you are getting 3 years warranty and a good deal, go for it..
Don't chase brands, chase VFM products as far as LED TV's are concerned..The product life is not so great compared to CRT's..
Some cover only panel in 3 yrs warranty.. Rest of the hardware is std one year only for most manufacturer's..
Please check with manufacturer customer care and make yourself aware of these details..
How is picture quality of it? Is it same with VU and Micromax?
