Need advice on Speakers for Pioneer SA 508
Ambu
Pune
I purchased a Pioneer SA 508 Stereo Amp. Need suggestion on going for which speakers will give me best out put. Need to know place in and around Pune to buy. my budget is upto 20k.
Please advice.
Ambu
ambu,
please provide your music tastes, room size etc.. normally people look at bookshelves for a small-medium room size.
rgds,
mpw
Hi MPW,
Thanks for reply, I have got a medium size of room and like to listen instrumental, classics.
please suggest bookshelves which sync with Pioneer SA 508 to provide best music, my budget will be till 20k.
I would suggest MS Aviano 2.. Has awesome mids and highs.. if you do not require much bass then these are best within your price range.. could also try Monitor Audio bookshelfs.. Talk to Rohit from Rohit Enterprise.. I guess he has MA bookshelfs for demo.. Not sure about the prices though..
Happy hunting..!!!
I've never heard a Pionner Integrated.
However the safest bet would be to head out to AV shops with your Amp and try out speakers in your price range and pick the one that sounds best to your ears and has synergy with your Amp
However speaker brands you can look at
PSB, Monitor Audio, Morduant Short, Wharfedale, Dali, Quad
Visit
AVxellence - DP Road
Sound Factor - East Street
Soundscape - Aundh
Rohit Enterprises
Aquarius - East Street
