Need HD Media Player Under 5K
bpranay
Chandigarh
Hi FMs,
I am on lookout for a HD Media Player. My requirements are as follows:
1.One which should upscale movies from SD to HD.
2.Should support all HD audio formats (with 5.1surround),video formats & subtiles formats
3.Should have sufficient USB slots,HDMI out/in,Optical/coaxial
4.Can be connected to my 1TB HDD
5.Should be future proof for at least upto next 5 years
My budget is 6K and I'm planning to connect it to the AVR which I'm soon going to buy. So I think my options are
1.Kaiboer
2.WD TV Live
3.Asus O!Mini Player
4.Xtreamer
So kindly suggest me which one is best out of above 4 with their pluses and minuses. Is there any other option apart from above. I want to stick to branded ones only. So waiting for your inputs.
AVerLife HD Studio is a powerful Full HD 1080P network media Player With a potent processor. So you can play Full HD 1080P movies and video files on your TV. AVerLife HD Studio makes an ideal home theater in your living room with high-definition entertainment system.
Thanks for your input.From where can I source it?what is the cost? Warranty status etc.
Have a look at Kaiboer K6 based on 1186 under 6k with Wifi. Supports 3D videos also so would be future proof.
Any one tried Kaiboer K6, I am planing to buy one. Please post a review if any one is having it. Thanks in advance.
Prabhu
