Need help buying my first Audio setup in tight budget
vijay96
vijayawada
Hi folks,
This is my first post here on the forum, so please bear with me if I make any mistakes.
I'm looking to set up a basic Hi-Fi system within a budget of under ₹18,000 , primarily for movie and music. I know this isn’t much to work with, but it’s all I can afford at the moment. Eventually, I’d like to expand the setup over time as I invest more.
Initially, I was considering a mass-market 5.1 home theatre system or even a soundbar, but I’m pretty sure those would lack clarity and detail. Since I'm not doing full surround sound right now, I’m leaning toward a stereo setup with active bookshelf speakers , focusing on quality over quantity but I am going to invest gradually on AVR, Sub and Surrounds.
I'm open to suggestions — whether new or used gear — and I'd really appreciate help in putting together a great-sounding system that gives the best performance possible under this tight budget.
I'm based in Vijayawada, Andhra Pradesh , so if anyone has recommendations for local shops or pre-owned options in South India, that would be very helpful too.
Thanks in advance for your time and advice!
You may have to resort to a budget Active loudspeaker like an Edifier. Unfortunately you cannot expand or extend this to a Home theater later on. However, this will sound way better than all the plastic Htib junk.
Alternatively look at Norge. They do have something within your budget. Its a good brand to consider when you are starting out.
Used is usually the better path to take. More value for money. That said, I have yet to come across anything within the price range you have. The quality of the equipment is always an issue at these price points.
