Need Help for Matching Speakers
  • Thread starter Thread starter Deleted member 25636
  • Start date Start date
D
Guest
Dear friends,
Kindly pair the bookshelf speaker to the following stereo integrated amplifier for the excellent sound. 1) Harmon Kardon HK3390 2) Denon 3) Marantz PM Series 4) NAD 5) Yamaha 6) Cambridge Audio Azur.
Thanks & Regards:indifferent14:
what do you ultimately want to achieve in asking this question. are you looking at buying a system or just general knowledge. theres no perfect match for all. it depends on what type of music signature you prefer and also what sort of music you listen to
I just want to purchase the right one. so, that i am asking friend, not for general knowledge and also no need to gathering the same.
demo it.its very imp.see what suits ur ears.and which of the int amp are u presently having above those? if possible take it and pir spkr with and have a demo.
It is hard to get a demo in one's own listening room but that is the only way to find a good system.
I had to go through many changes just to realise that NAD and Wharfedale combination gave the best sound (within my budget) in MY ROOM.
what is your budget / room size. also what sort of music do you listen to. imo you should first decide on a set of speakers and then pair it with a suitable amp
