Need help on screen size for Benq 1070+
poppy
Friends after long search and help from forum finally I was able to finalise on speaker/av/pj.now on screen .For pj decided to go for Benq W1070 and screen 92" Grandview but confusion is on pj placement and screen size.
-------------- --------------------------' .front wall planing to put screen
! ---'--11"feet--------
! Distance between front / rear wall 14.7"feet
-------------- ---------------------------Rear wall
Total area is 295"..
I want to install pj roofmounted at around 13.5" feet 1 feet ahead from rear wall but not sure whether it will cover 92 " inch.
Need some advice where to install pj.whether if I install as above mentioned 13.5feet will have to install a bigger screen or for 92" inch I have to take the pj ahead.can someone pl help as guy from whome I am buying systems is not aware of Benq setup.pl help as I am new bee in this.
This will help me to complete my HT setup.
