Need Help with Blaster 2.1D by Astonia
vigneshiyer
Hello Guys,
I am planning to buy a good budget HT system, that gives decent performance, worth the money (and shouldnt regret it after buying it)
I got a small hall (10 * 10) where i plan to use it
Bumped across this 2.1 set in ebay.in
Astonia Audio 2.1 Blaster
Astonia audio
Had a word with the owner he claims good performance along with
SC 300 Amp
Astonia audio
Wont be able to test it personally as i am in Bangalore and the store is in Mumbai. Would like your reviews on the same. Has anyone been there to the store to experience it.
Thanks,
Vignesh
The Astonia 2.1 system still needs an amplifier? Doesn't it come with built-in amp like other 2.1 brands?
Also look for Edifier C3. It has got good reviews. Available for less than 8K in infibeam. flipkart price is high.
Its a passive subwoofer, will need to back it up with an amp. Astonia has a budget amp (SC300) was planning to add that as well. Its been recommended by AV Max as well. My question remains should i go with a passive sub or should i invest in an powered sub. Either Astonia Df10 or Sonodyne PQube.
which one would be a better choice
Vignesh
