Need Suggestions on LED Projector and Screen
JackSparrowGH
Jaipur
Hi friends.
I am new here and its my first post at here. I came to know about HiFivision on an another popular automotive forum and started following it since then and gained lot of knowledge.
I've been regularly noticing lot of friends here from that automotive forums :D
Now let's come to the topic....
Projector:
I've decided to buy Benq GP2 LED projector (Obviously decided after reading a lot about projectors at HiFIVision).
Question is, how is the decision? I usually watch movies in the night with lights off. If I mount the projector on a tripod, I get clear 8' of length between screen and projector in my 15'X11' room.
Is there any other projector, especially any true 3D projector worth considering in this price range? I am getting it at around 35K at a local Benq store. Have also went for a demo and found the image quality and resolution really good considering the low price point. I would also use this projector as my portable presentation tool.
Screen
Here comes the problem. My center speaker is placed at some 8'-9' of height on a shelf. My initial plan was to go for a ceiling mounted screen for aesthetic regions. If I go by this route, the screen will be around 24" to 28" away form the center speaker and the speaker would be hidden behind the screen. This is surely a problem.
I am on a tight (rather tightest possible) budget when talking about the screen. The projector seller quoted some 6.5K for a manual folding ceiling mounted screen. A dedicated screen seems better choice considering the projector is a LED type with just 200 lumens max.
There is no suitable wall in my HT room-cum-studio wall so screen is the only option. Since it is my work studio as well, I will also have to maintain aesthetics from interiors point of view and would not be able to move the center speaker form it's position.
How about making some tinny holes in the regular screen in front of center speaker? Would these holes distract the movie watching experience?
After digging a lot, another option arises is the tripod screen so that some space can be left over the screen to clear the path for center speaker, but the bottom of the screen may become too low. I want atleast 8' wide screen which would be watched from some 10' distance.
Suggestion awaited.
Well, here are some thoughts came in my mind about setting up the screen:
This is existing layout, (please read the dimensions in inches instead of mm. 142mm means 142 inches):
How about making a ceiling mount screen with transparent kind of cloth on top part and then bottom part is made of actually screen material. Something like this:
And this is tripod screen layout, but least preferred, I don't think it is more practical and convenient over the ceiling mounted screen:
What say?
Hi friends.
Projector:
Screen
I am on a tight (rather tightest possible) budget when talking about the screen. The projector seller quoted some 6.5K for a manual folding ceiling mounted screen. A dedicated screen seems better choice considering the projector is a LED type.
Welcome to the idea of moving to projectors. Benq GP2 has got good reviews from other forum members and you can PM them to know of their latest experiences. I personally started my search for a projector whilst zeroing on Acer K330 but then moved to standard bulb based one Acer H5370bd.
If you want 3D, my personal opinion is you will need more lumens than standard 200 to 500 limems provided by most of LED based PJs, except the latest models from LG. Also, a 200 lumen projector will not be able to serve the purpose of projecting slides for a business meeting until and unless you completely darken the room. At your current budget, the Acer seems to fit the bill.
Have no first hand idea on screen so cannot comment on that.
If power consumption and lamp life is the concern, the acer 5370 is 230 watts only and has a lamp life of 5000 hours in eco mode...
good info,if you are interested in preowned, there is one Acer K330 in for sale thread.
ODzYjZ
