Need Wall mount For 5.1 Speaker
sarge
india
Dear Guys,
I need a wall mount for both sony dth theatre ht-iv300 & Logitech z5500, can anyone tell me from where should i get ?
Amazon has a lot for sale...depends on what is the key hole or thread hole on these speakers...refer to their manuals...
Tono Systems make excellent stands...
You will need to post a pic of the rear of these speakers for me to give you a pin point model
any suggestion ??
Apologise for late response...been a bit tied up...
Besides the various stands you get over amazon or ebay......the other jugaad way is to possibly drill holes and use some clamps...thats what i did for the Bose 301 series iii to be wall mounted....you dont get proper stands for these....ended up putting clamps used to hang wall paintings....(nut n bolt)
Was searching for Youtube videos which would have been posted by someone.....cant find any at this point in time
