No Sound From Laptop Headphone Jack
victorjohn9211
Erina, NSW
I am using Jabra headset, this is not working with my specific laptop HCL ME.
This headphone is working with other laptops, desktops, and mobiles too.
So please let me know the solution.
Hi. I've not used a Windows system in a long while (been on Linux and ChromeOS). I assume you're on Win 10. Updating sound card drivers normally used to fix such issues for me the past.
If I'm not wrong, right click the speaker icon in bottom taskbar, select "Sounds" -> select headphones listed -> properties -> update drivers. Select automatic update option, and restart PC after the process. The headset should be working now.
Does other earphones / headphones work on your laptop? Check that before checking the soundcard of the laptop. Disable and Enable the soundcard in Device Manager
