Noise cancellation headphones under 6k
Maybe you should look at in ear phones if you are comfortable with that type. This gives noise isolation as against noise cancellation. Noise isolation has none of the noise cancellation electronics so it is supposed to have more accurate sound reproduction. They are also much easier to pack!
I have been using Rs 2k-2.5k Philips in ear for quite some time for travel use even on long international flights. I have a problem of sweat caused by over ear so I went for this and am very happy. I have been used to wearing ear plugs in my rather noisy work environment so I knew what I could expect re wearing "feel".
You should be able to find good ones for your budget.
