Norge 2030 vs Norge 2060
Amateur_Audiophile
delhi
Hello -
I am planning to buy a budget amplifier and confuse between Norge 2030 vs 2060.
I will be using Diamond 9.0 speakers with a polk audio suband mostly it will be for music.
Need expert suggesntions
What is the size of your room and what is the listening distance?(distance between speakers and you). For room smaller than 14X12 and listening distance less than 10 feet, 2030 will be more than enough. If more than that, 2060 is safer bet. Before buying, ensure that the piece you buy has pre/line out so that you can connect subwoofer later.
2030 = 30 + 30 W
2060 = 80 + 80 W
Go for the 2060 - more power, widely popular & proven model. Pairs well with the Diamond series. It doesn't have a separate sub-out but that is not a problem with a decent sub that has speaker level inputs.
2030 = 30 + 30 W
2060 = 80 + 80 W
+1 to that! THE most popular workhorse from the Norge stables --- the ever dependable 2060! :yahoo:
