Now ground yourself!
I took pride in myself being "well grounded" in this hobby.
Now these guys have burst my bubble. Damn!!
Raghu
After grounding your kid , you can now ground yourself using these . One advantage being you will no longer be 'shocked' in any case :p
Well , if there are audiophile audio racks , why not these ?
After a certain point , it’s not even about sound anymore. It’s about exotic hardware to showcase and impress ! Who gives a damn about what any of it makes any perceptible difference to SQ.
Keeping the legs in a bucket with warm water and salt which is earthed (with the Meta Ground) gives more immersive, soothing experience while listening to music. I need a patent now
I am not sure if this is grounding the listener OR grounding all equipment Via the listener !
Then there are ground problems eg Hum in Phono-stages. touching it reduces it.
I'm picturing myself with a grounding strap attached to my wrist and the other end going to a ground rod in my room and me holding on to equipment for them to ground via me, the listener. It's not a pretty picture at all!!! :p
Truly a breakthrough in grounding topology, but they made one error.
They should have grounded around the waist (waist strap) and not the wrist (wrist strap).
It would have added more fat to the music. ;)
add a claim "it also grounds the fat"...and you might have the next Unicorn :)
So a system with Kharma Signature loudspeakers driven by Pass Labs and MSB equipment (I am assuming middle of the line) sounded dull, pedestrian and shadowy ? And it took the Shunyata Zero IQ grounding system to make it sound magical? Keith, can you share the name of this guy who wrote this as well... I don't think he is going to get any more equipment reviewing from Kharma, Pass Labs and MSB in the future...
Q: What do you get when a failed writer of fantasy fiction goes to a high end audio show ?
A : A Hifi reviewer
Actually you got it wrong way up! The dull, pedestrian and shadowy sound was with the Shunyata thingie attached! It does make a difference!
