NTSC signal
In india, we have only PAL transmission. so you wont find any settop box which will give NTSC output. I guess you bought LCD in US and want to use in india. in that case you dont need NTSC settop box.
go for HD settop box and connect your LCD through HDMI port. it will work.. :)
hi,
sun HD will support NTSC as per the info gathered from the net. you may try and let me know.
cheers
hi,
cheers
It will not work. You will need a converter like this :
Amazon.com: Atlona AT-HD560 Pal HDMI to NTSC HDMI Converter 1080p: Electronics
See the user reviews on amazon for this device.
A user from India has stated:
Kiran K. Vasu (Bangalore, India) -
This review is from: Atlona AT-HD560 Pal HDMI to NTSC HDMI Converter 1080p (Electronics)
Finally, I'm able to use the TV I bought from US in India. I always knew about the PAL vs NTSC issue, but I thought this was a non-issue with HD programming(since the resolution was the same everywhere). Only after hooking up my Sun HD satellite box, i discovered that does not work either. Ordered this from Amazon and it works pretty well. HD channels look great, and SD quality is acceptable.
I am using a converter to convert from NTSC to PAL, I wanted to know there are any DTH provider that provides NTSC output.
I tried at ritchie street yesterday, the menu of sun direct gave the following options:
1. pal
2. ntsc
Hence it should support ntsc tv. You may go to ritchie street and satisfy by checking it personally before ordering a sun direct or sun hd.
Alternatively, pl go to any forum member who is using sun hd and check. Pl. keep us apprised.
cheers
ya, i too, have bought ATLONA -
Atlona :: Products :: Converters & Scalers :: PAL NTSC Converters :: ATLONA MULTI-SYSTEM PAL/NTSC VIDEO CONVERTER
superb product - converts NTSC signal to PAL -
made in china, though:o
