Odyssey Audio repairs
franz
goa
I need my Odyssey Audio amp checked into.Does anyone know a good techie in the Mumbai or Bangalore area?.
Thanks,
Franz.
hola,
ARN systems in Bangalore - mr sridhar reddy is / was Odyssey audio dealer
do check with him
website available
regards
Mr. Sridhar Reddy is no longer with ARN and ARN does not deal in Odyssey anymore. You can try e-mailing them, but they may not service the product. Better for you to search for a competent independent tech. Some reference are available on the forum so please do a search.
Sid
Call klaus at a good time.
He is not good at replying emails
He surely will try to troubleshot the issue
If you can find out what's the issue you can suggest him to send the parts if the amp is under warranty
Also you can post here if you like what exactly is the issue with the amp
