Onkyo HT 3300. How good it is?? Is something better available in 25K??
mayurtop
I am planning to buy Home Theatre with AV Reciever and speakers in range of 25-30K. I liked Onkyo HT 3300, is something better availabe in same range? or this one is good??
at this price range 3300 is best available ,if you can stretch your budget there are lot more options.better you can go for av and separate speaker package if you extend your budget.
None better than 3300 available,, i too planned one but iam extending my budget to 45k, because i want 7.1 output so going for avr508+ tall boy speaker system.. Going to order in june..
going for A/V receiver and speakers separately will give you more options.
Select a receiver which has got the features you need. May start with 2 speakers and later on add sub-woofer and surrounds if your budget is limited. It is better to build step by step instead of compromising for lower models due to current budget constraint
