Optical toslink cable - mini on both sides
amit11
Pune
Hi Friends,
Is there any mini toslink to mini toslink cable optical available?
I do not want to use the connector and attach, it degrades the quality.
I have 4 optical cables.
Blue rigger - one side mini and other side normal
Blue rigger - both sides normal
Stock optical cable which came with bose bluetooth adapter
Stock optical cable which came with ifi spdif purifier.
Its hard to believe, but all sounded different by slight margin and the worst was the last one which changed the tonality to much extent.
I too now started to believe that optical cables make difference.
Compared to 1 and 2 even though both are from blue rigger, the only difference was attaching the mini connector to the second one. Even in that i could feel a difference.
I experimented so much for the first time since i have to now use 2 optical cables after introducing ifi spdif purifier in the chain. I experimented with all permutations and combinations using these 4 cables and using two at a time (before purifier and after purifier). Had to scratch my head listening to all 4 C 2 combinations.
So this time, my requirement is both sides mini.
Thanks in advance.
Amit.
