Peerless driver for HT
swpnit
kolkata
I want to build 1 centre speaker and 2 rear speaker.
Only movie purpose and My AVR is Yamaha RX V-371.
what will be best driver to build those.
Tweeter section already choose
Peerless - 25mm Fabric Dome Tweeter - SR10DT
For woofer i am confused please help me on this,
Peerless - 4" Coated Paper Cone Woofer - M10NG
Peerless - 4" Coated Paper Cone Woofer - KO100
Peerless - 5.25" Coated Paper Cone Woofer - M13NH
Peerless - 5.25" High fidelity 8 Ohm woofer - SKO130
My room size is not very big but i do not want loose any frequency response.
AVR crossover set on 80Hz.
Thanks in advance.
Swarup
Peerless - 5.25" High fidelity 8 Ohm woofer - SKO130 may be good choice.Also its has good sensitivity.I had a chance to pair a BS made of the same with Yamaha 667 & sounded good with movies & music.
I have built HT Speakers using Peerless M13NH & Aluminum Tweeter TL25AN. Though these are meant only for HT, they do surprise me when used for music out of curiosity.
Jayant
Jayant
You did? Whats the enclosure dims and the x-over like? A pic. would be nice too :D
What is difference between SKO130 and M13NG.
Which tweeter should i take fabric/almunium or silk.
driver choosing is really confusing.
:sos:
:sos:
:sos:
