Pioneer HTP 071 for 12x15 room
Venkat P
Hyderabad
I am on bit tight budget looking for HTIB I see below offer from snapdeal.com
Pioneer HTP-071 5.1 Home Theater System for 20k. Seems like good offer.
Pioneer HTP-071 5.1 Home Theater System - Buy Online @ Rs.19999/- | Snapdeal
I plan to use this system for a HT room of size 12x15 primarily for movies. Is this offer good or should I look at Yamaha 196?
Dont have much budget more but I see Yamaha 296 at 30k at pepperfry.com but I heard Yamaha is good primarily for music. Also not sure I will be able to spend more.
So is this system good for primarily movies usage? Is this upgradable?
I was checking and thought to increase my budget a bit. I can find Denon DHT-1513 for around 38k at HTStore.in. also there is Yamaha YHT299. Which of the two would be better for usage primarily with movies and occasionaly with Music (~ 30%). Are there any other alternatives in around 30 to 35k range?
Also there option of Harman Kardon AVR70 with HKTS-5 Speakers at HTStore at slightly higher price range. Dont see much review for this system online. Cannot find this at stores nearby hence cannot audition this.
