Pioneer vs Kenwood - Which speakers are better?
they must have relesed hundersd of speakers - which may be from pathetic to super! Unless you give specific models and at what price they are available TO YOU - not some remote auction site in Europe - IMHO this query is futile...
The sub looks like it will need a decently powerful amp to run well. The component speakers looks okay. Of all the Kenwood subs I got to experience, they had a smooth (likable) bass. I liked Rockford Fosgate component speakers.
Sir,
We have already posted on your current thread to go out to car audio shops and listen for yourself. Asking if kenwood is better than pioneer is like asking if Chicken tikka is better than chicken Fry.
Sir,
good one ....:ohyeah::ohyeah:
Or asking is Black Label is Better than Chivas to respective fan camps.....
Hi Bublu Bhuyan
For any good speakers you need to see what frequencies are getting covered. (20hz - 20khz). The speakers that cover the maximum frequencies is definitely good. The Higher the sensitivity, the better it is as it will match and run on low / mid sized amps.
End of the day it depends on what appeals to you in terms of listening and what is within budget. Pioneer has been in the Car market for years and their decks are reliable performers and some of their speaker models.
Hope this helps.
yes,they had a smooth (likable) bass. I liked Rockford Fosgate component speakers. thanks
SShln1
