Planning for a micro-OB speaker
Hari Iyer
I have done simulation in Basta for a pair of micro-OB speaker using the export surplus drivers (Canada) from IWAI. The results are quite encouraging and this allows me to use the drivers without using much compensation network. Also the dimensions are very encouraging for allowing portability in different rooms and situations. Again i have used golden ratio for both the baffle and driver positions. The roll-off is around 110Hz and is flat above that as per the simulation. For most situation, this can still be used without a sub-woofer, but using one below 100Hz will be more beneficial IMO. Will post simulated results later.
Thanks for looking.
