Plantronics backbeat pro
abird
Kolkata
I bought a plantronics backbeat pro from UK, used it for 7 - 8 months. When I opened it after 3 months yesterday, I can see there is a bit wear and tear in the headphone. Attached are the pictures.
Can anyone please help me know how to fix this.
Sent from my ONEPLUS A5000 using Tapatalk
You could try this:
How to fix damaged ear cushion in headphones?
I would be a careful about actually applying the fevikwik to the surfaces to be glued which he has glossed over. It has a habit of smearing itself all over the place, so I would cover everything that isn't going to be glued with masking tape before applying it.
