Plasma TV or LCD TV
Personally, I recommend a plasma... compare fast moving scenes on both and also compare the image from different viewing angles that you are likely to use at home.
I am looking to get 42" LCD TV and the shop that i walked in recommended me the LG 42PJ350 Plasma TV (LG Razor Frame Design Plasma LCD TV - Model 42PJ350)
Between 42" LCD and 42" Plasma TV, could you please recommend which one should i go for?
sanlen
Welcome aboard friend. Please use the search option in the forum, there are numerous threads which clarifies your doubts.
Yea, already to many duplicate posts and replies, please use the search option and enlighten yourself.
multiple threads and details discussion bout plasma v/s lcd in many scenarios....
happy searching.. and welcome aboard
Hi All,
Thank you very much for such a good advice. Is LG that i was recommened is ok to take one? Can you please advice or suggest me a good one?
sanlen
