Please help me to build a system
sagar7877
india
I do have rx v 671..want to buy TSi200 as front speaker..should I add polk blackstone TL1600 as rest of 7.1 system?Will tsi200 work well with TL1600 subwoofer and center speaker?
25ft*12ft....tsi200 will be front speaker..maybe go for tsi300..but I am confused about rest of the system....I can add tl1600 or..i can add tsi100 .psw110..separately...main concern is will psw110 and tl1 center speaker match with tsi200?
yes they will match definately,in my opinion no need to add floorstanding speakers in hometheater , as you mentioned above go ahead with TSI 200 pair for front , 2*TSI00 pair for surround and surround back, and for center add CSI 20 with PSW 110/125 for LFE, this system is more then enough for room size you have.
ok.but if I add tl1600 polk blackstone...that will make my system 7.1 instantly.I am not sure tl1 speaker comes with that package will be enough for surround and rear surround..but will subwoofer and center will be enough to match tsi200?and another question tsi200 and tsi300 ..is there any significant difference in sound quality between them ?
