Please suggest Bookshelf Speakes in 10k budget
nik
Kolkata
Hi guys need your help could you suggest some good passive bookshelf options in the 10K range.
Looking for anything in the 50-100w RMS range.
Mainly listen to EDM.
They dont need to really powerfull on the bass as I got a powered sub
The only option I could find are the Wharfedale Diamond 10.0 & Q Acoustics 2010
Any help will be much appreciated.
TIA
Thanks a lot guys, will audition the polk and wharfedales and then decide.How much would the diamond 9.2 cost though?
Or participate in the group buy of diy bookshelf speaker kit. Those will be hard to beat for the price.
well, it is not exactly"diy", we are importing the kits and getting it assembled professionally(at least i am. Me aint got any wood working skill nor have the tools )
I am quite happy with my Ventronic book shelves. Got them for 9k. Made in Mumbai. MTM Design. No specifications given. But sounds great. Dealer says it is 4 ohm. My Marantz 6002 does not even get warm while playing those. So i take his word
where in mumbai can u check these out??
sub 10k speakers sound tempting.. enough to warrant a check out
