Portable Media player Decision.
prashant_dv
Hello All,
I am planning to buy a new portable media player. I have a lot of FLAC files and would like to have a player which can accept FLAC format. I do remember reading about COWON D2 player. What is the approximate cost of that player today ?
What else are the options that i can lookout for on a portable player front ?
Do you require video capabilities ? If you don't, you can use Sansa Clip+ . Its good, plays flacs, and takes microSD cards. available on EBay only.
However, if u do need video, lot of people recommend the Cowon D2.
In that case, the clip+ is probably good...It can also be rockboxed...The SQ improves. and there are various options. The clip+ is ~3100 on ebay. The seller is in mumbai.
This is the only player I have used till now..So can't really compare with others .
Since you are in Bangalore, try to see if any other forum members there have any portables and if possible have a listen in before deciding.
