Projector screen advice
anupum
New Delhi
Hi Guys,
i have an old projector Sony VPL ES2, which i use for watching movies. I recently purchased a home theatre and am now planning to buy a projector screen. Can u suggest the size of the screen that i may buy ?
I'm amateur in this area or fresher as u can say and would request for advice on size of projector screen, white or gray and also the ideal distance of projector from screen.
Anupum
Spend a little time looking through some previous posts and you will get a fair idea about distance, as well as local screen options.
What is the size of your room? We need to know that to suggest anything.
White screen is most common, cheap and easily available. I would advice that.
i need few doubts ,i recently bought a home theatre set up which consist -optoma es551 projector/onkyo tx sr313 hd av receiver/wharfedale vardus speaker package with a sony bdv e 290 bd 3d player.
now the problem start with my room the spec is 8 ft by 18 ft. so i can hardly fix a 100 inch screen in width wise.
now please advice whether the room will do or it is not at all good enough for a a mid level home theatre set up ???
another question is am not gona invest any huge money for screen as am planning to nuild a dedicated room for this,
for the time being how i will make a temporary projector. am not able to find any store who sell the black out cloth .can i use flex board sheet for the same ????
PLZ ADVICE .....
