Wanted to share my solution for a low cost media player as a source for my DAC. Normally I use my DVD player as a source for my Schitt bifrost multibit DAC but wanted to have a media player easy to control using my iPhone as a remote to use occasionally. While I was looking for a reasonably priced solution, it suddenly occurred to me to use my raspberry pi3 using the USB output. Quickly installed OSMC on a SD card, configured the audio output to USB, changed the maximum sampling rate to 192 kbps and was able to play flac files off a USB drive. I could control the pi3 using the Sybu Kodi app on my iPhone.I was also able to connect the Pi3 to a stream magic USB input as well. Other USB DACs may work as well. One thing I noticed was that even playing 192 Kbps files, the stream magic display showed only 96 Kbps. Dont know why and where the downsampling was happening. Overall it was a pretty stable and inexpensive solution. If any of the forum members use the Pi3 as a audio source, would like to hear about their experience.
