RCA Analog to 3.5mm
hstejas
Hi Folks,
I'm planning to buy a Bowers and Wilkins Z2 dock for the bedroom.
The review look pretty sweet and I auditioned them.
MY question is since it has a 3.5mm input would I be able to connect a CD player to it which has Analog RCA?
I'm planning to play 320kbps mp3 files from the USB in the CD player, making use of its DAC which would definitely be better than a DAC in a Android phone/mp3 player.
Is there an accessory to convert the analog RCA output from the CD player to 3.5mm input?
If so, could you please post them.
Hi Folks,
it is simple cable
Amazon.in: Buy 3.5mm Stereo To 2 RCA 1.5 Meter Cable Online at Low Prices in India | PTron Reviews & Ratings
MX AUX CABLE 3.5 MM STEREO TO 2 X RCA - 1.5 METER: Amazon.in: Electronics
you may get unbranded for Rs 50 too !!
Hi Hemanth,
This is not what I'm looking for. I'm looking for the opposite of this one.
This would be used to say plug in my iPhone to a stereo amp.
What I need is something like plugging in the analog audio out from a CD player to
A dock that takes in 3.5mm input.
Hi Hemanth,
SOOO?
Cable is not Directional:rolleyes::rolleyes::cool:
here 3.5 mm will go to Dock
2 RCA to CD player...
koi shaq?
Wow! Never realised that might work. Always thought of it like male-female ports. Feel so dumb right now :)
Thanks guys. will try that !
These things happens even the most learned ones make mistakes.
I once put a capacitor in place of a resistor and spent 5 hrs deducing what was wrong with the circuit as it was not working :D:D
