Re: 50inch TV for second home
Ghostrider
India
kindly advise smart tv for second home, will be used usually over weekends and will be opting for 50 inch, will be taking dth and need option of hdd or later use some media player, as of now need advise on running brands MI / TCL which are in range of 25-35k but not sure on quality and service, also their loaded android version comes with Netflix n prime.
Am currently using plasma and hence quality will be needed but at use will be limited I would prefer to save on cost too, if not a big difference then should I opt for LG/Samsung and add some smart stick to it !!
thanks in advance
