Receiver Service Centres
binaya.kumar
Hello,
Since, most of us get AV receivers from US and use it in India (so no warranty in most cases), I thought it will be good to have an idea about the best Service centres that are available.
Currently I am looking for a service center for Pioneer receivers in Bangalore.
There might be a few in here but it will be good to know the best place to go for because all of them are not same. Charges, Service, Quality might be different and there are some experts who are better than even the authorized ones .....
CHEERS
PLs get in touch with Mr Kamat, Kiron Electronics, Bangalore. He is based out of Hanumantha Nagar. Contact no 080 26670028. He is a very resonable person and has some 30yrs of experience in this field.
Always go for a manufacturer authorised service center,if the problem is solved and resists again u can claim on it and whats done in ur system will be transparent,if ur going for a local service man who will charge u more in some cases (depends upon the service men whom ur dealing with).if ur a novice then there is a possibility that u can be betrayed , no one knows if the fuse is gone or mother ic is gone, its on ur own risk to opt for a local service man....
Most of the service men comes to our home in our office hours ,take a wise decision and decide ur self buddy ,no offence met....;-).
Kiron Electronics which is also known as PARAS AUTHORISED SERVICE CENTRE is the authorized service center for Pioneer (as given in their site), they are also the authorized service center for Yamaha among others!
I had a good experience with them! So I would recommend using their service unless you found someone better!
