receiver+speakers or mini hifi system???
guddu
kolkata
i am currently using sony mhcgzr5d mini hifi system.but i am planning to replace it.
but i am too much confused.either to buy receiver + bookshelf speakers or go for mini hifi systems????
which sounds better under a budget of 30000rs.
the sony mhcgzr888d is 600watt rms and 6600watt pmpo.i hv also heard that the bookshelf speakers are very good if combined with quality amplifiers.
please help me sir buying a new system.my room size is 12x10.
please suggest me what should i buy?????????:sad:
thank you.plz help me.
at 30k you should get a good pair of bookshelves with a stereo amp, give or take a few thousand. for speakers look at the wharedale diamonds, usher s520. the bose 301 at 17k is a well rounded speaker. for amps you can look at nad / cambridge / yamaha / marantz (in no particular order). once you decide on the speakers you can then go about matching it with an amp to suit your style of listening
thank you very much for ur advice.I hv decided to take the wharfedale diamonds 9.2 nd nad for the amps.
