Recommendations on speakers made for music.
BlacX
Latvia
Hello,
Any recommendation's on what speakers are good for music? I was looking at Logitech Z906, but then I found out it didn't had HD-audio(bummer). I am mostly listening to EDM kind of music. Budget is around 700$.
Thanks!
Hello Blax,
Welcome to the HFV.Could you share the Source,Room size, So the FM's could give their suggestion.
Since you prefer Music, Go with Stereo set-up instead of 5.1\HT.Thats better
Hello Blax,
Hello Blax,
Hey,
Room size is 17 m2 and I am mostly using my iPod for music.
If i understand well then its 17 Meter Square ? I s that right
Its best you buy a Powered Speakers namely Dynaudio DBM50 \Genelec 8010A\Paradigm Shift A2.
If are fine to have Amp+Speakers set up, Thee are Lot of Options
Yes, you understood 17 meter square. So you're recommending purchasing one of these speakers?
