Regarding Tweater
magic.murugan
Chennai
I found most of the cars audi system with two teaters at the front. Even though I enjoy this effect, after some time I am getting head ache.
Is this the side effect of all tweaters or because of low quality tweaters. Will i hve this problem if i go for high end tweaters.
Has any had this problem before ?
SMS
Try reducing the high frequency using the treble control or equalizer. High pitched tweater sounds are irritating to me also.
You answered it yourself. There are equalizer settings to be seen as well. The quality of tweeters , The head unit they are running fro , the wiring. Everything has a role to play in the final output.
May be you like laidback music and the other guy(in whose car u sat) likes sharp.
Try to change the equaliszer settings if your not satisfied with the output ,buy good tweeter with good crossover.
