Revolutionary soundproofing material
captrajesh
Moderator
Staff member
Mumbai/ Hyderabad
An Australian company claims to have concocted a revolutionary new material offering superior sound proofing properties occupying much less space releasing expensive real estate!!:)
Read about it HERE
The Actual Cost Is More Then One Can Imagine
If one makes a dedicated home theatre and let's say the cost is 20 lacs covering all audio & video gear, acoustics, interiors, etc. while the room cost property wise would be around 40 lacs due to expensive real estate, so it sums up to 60 lacs for a private theatre, this is indeed mother of a passion.
The very thought if one has spent 60 lacs on a theatre, is mind boggling.
V.
Re: The Actual Cost Is More Then One Can Imagine
V.
are you referring India or us?
BTW there are many people in india who must have spent crore upwords in HT ,if anyone consider real estate cost...
BTW I was told Panasoinc plasma 103 Inch ,costing 25 Lacks sold 20-25 Pieces in Mumbai alone ( as per one dealer!)
Passion
Indeed there are people who have spent a lot, why a crore, how about 10 crore, the point is how much is your passion, which is not determined soley by the money you spent, but how much do you make it value for money, like for example after investing big monies and still going to a cinema hall for watching movies, etc.
V.
i think what captrajesh meant was that if the sound-proofing material is revolutionary (and compact - say one tenth the thickness of obsolete materials) - it will free up space in the room (real estate) -
so that a bar cabinet can be installed - stocked with Amrut single malt and also single malts from all over the world
Hi CaptRajesh,
That material you are referring to is an acoustic barrier - effective to prevent sound being heard from one space to another.
In a room, you would need acoustic absorbers to control the acoustics in that space.
The two functions, isolation and absorption, are quite independent.
Viren
one is to save you from room reflections etc spoiling your music, other is to save your neighbors from torture of listening to your choice of music.
