Roon Audio setting
johnmicheal
I have kept all options default in Roon Audio setup,if some one has optimized it for better sound quality, please share settings. Thanks
What's the hardware Roon is running on? Most of the time default settings just work fine.
If you are using headphones, headroom DSP helps. I have not tested.
Sample rate conversion to DSD helps if your DAC supports it. Tested to highest PCM sample rate (my DAC does not do DSD) but could not find any diff. Reverted.
I have a dedicated computer with good configuration for Roon Core
Roon automatically scans the underneath audio hardware and picks the best possible supported settings. Apart from that you can play with DSP filters but they can create more trouble than refinement if not done carefully.
When I upsampled my audio to 2X DSD I felt the sound was a bit denser (I have a DSD dac). Nothing earth shattering though, I could live without it.
The default settings are usually the best. If you want to tweak them, try disabling "load on boot" and mp3 encoding options. They can't be disabled in trial mode but I would highly recommend it for the full app anyways since they're only trial versions of what might otherwise be an excellent feature set.
I honestly think this is a gimmick that was hyped up when its release was announced; I wouldn't advise people to install something where these tweaks are on by default until more people have tested or tried out the non-default features and provide feedback as to their experiences with them and whether or not there are any meaningfully different effects at play between the factory settings versus what those tweaks achieve if any objective difference.
For me Convolution filter support helps a lot. It supports raw, wav or zip files. One can also use REW profiles.
Convolution filters help correction of frequency & impulse (timing) response in my system which has the maximum impact than any other feature including upsampling.
I have left it at default. No enhancements. I did experiment a lot earlier but now I just prefer it without any drama.
For hp users especially those having audeze it good as it has inbuilt settings.
I agree, headroom management, ability to load eq settings depending on your headphones are pretty noticeable.
