Rugged speakers to use with AVR
square_wave
Edinburgh
Guys,
I am looking for some rugged speakers for use in our office game demo system. The amplification will be an AVR since all gear needs to be connected via HDMI to the amp. The setup will be 2 channel only since it has to be portable. So thinking of getting some pro speakers like this one
Buy Online | Lowest Price | Free Shipping| Yamaha A10 10 2-Way Loudspeaker - Buy online at the guaranteed lowest price in India - BAJAAO - Buy online and Review Musical Instruments, Pro Audio, Studio, P.A. Audio Equipment in India
Are there any other options apart from pro speakers for this purpose ? The speakers should be easy to move around. Should not get damaged even if they are toppled down ( can happen during some of the crazy parties in the office ).
Wow this is something I actually have started noticing recently when I go around.
I've started noticing the brands that DJs have started using and if you have the budget the pro brands really are bullet proof!
Electro Voice (a division of Bosch) is a pretty good pro brand:
Electro-Voice Portable PA
JBL's Pro division has some very good gear as well.
Portable_Family
Thanks guys.
If I need to integrate a collar attached "wireless mic - mic reciever" and get this mic input mixed into the overall sound, will i need to buy a small mixer ?
Are there AVRs with integrated mic mix ( karaoke thingy)...
