Samsung 40" Series 5 VS LG 42 LD460
invincible
NCR
I am planning to by LCD TV of size preferable 42", brands I have finalized are LG and Samsung(In samsung not getting 42")
Requirements:
1. USB support for DIVX play
2. Screen Size-40"-42"
3. HD Support
4. Good Sound Quality Very Imp
Have two options:
1. LG 42 LD460 - Rs 50500
2. Samsung 40" Series 5 - Rs 50500
Please suggest for which option should I go for, and also let me know the best price for both if you know this is the price quoted by a dealer in Delhi.
The salesman was quoting two things Full HD & HD Ready for different TV - What is the difference?
Thanks in Advance
samsung c530 all the way !
Can you give reason, any plus points and if you know what best price I can get
One benefit i see in LG is that I am getting 42", which samsung does not have, and also sugeest me pros and cons of both and shud I look for Samsung C630 or there is not much difference.
I am also considering to buy samsung 40inch series 5 , i have shortlisted 2, 40C530 @ 51000rs and C550 @ 54000rs . when i visited the showroom C550 looked bigger than C530. so i am in quite a confusion in deciding between 2 of these models can any one figure it out, ny viewing distance is 8-10 feet, and cable STB and dvd player.
I think for your viewing distance, even a 46/47" TV would be good. You'd get a more cinematic viewing experience.
